NO Services Abroad
BCM
How do you speak to a live agent at shop in Bucharest?
The Online Djingo does not work
12 Răspunsuri 12
Hello!
You can't speak with an agent from a shop while abroad (it's not needed). I think you want to say you need to contact the Call Center. You need to have the roaming service active and you have two options: by credit (recharge with some Euros) or by the 12E or 16E option.
BCM
Hello I need to speak to someone at call center, can not use my number. I will call from abroad. What is the number to speak with a live agent?
+40374300300, and it can be used with any phone number (local or Romanian).
If you can acces your account on MyOrange, you can activate there the roaming.
Anca07
Hi @BCM
Did you manage to get in contact with someone? Also, I wanted to ask you if you can share with us what is the issue that you are facing, maybe we are able to identify a suitable solution for you here.
Have a great day!☀️
yes, after many attempts.
Barred Number? How is this? MbNot
number Barred
Hi @BCM
So, the issue is still persisting?
You have a subscription or you are on prepaid?
A barred number can occur from different reasons, and its dependable if you are having a subscription or prepaid sim card.
Either way, please come back with more info.
Thank you!☀️
YES ONGOING PROBLEM;  PREPAY;
Thank you for your answer @BCM
Since when you're in roaming?
Do you know about roaming policy? If not, can be cosulted Here.
Thank you!☀️
Hi Anca,
Did not use roaming at all as I am not a large talker.
Just trying to get the card activated or ported into a small abo so this problem does not occur again.
B/r
Got it, and again thank you for coming back and replying to me.
If you have the assistance ongoing for having the number moved to a subscription, I think should be fine.
Nevertheless, you can always come back in the community if you will ever need support.
Have  a great day!☀️
