Intri aici si rescrii (dupa ce te autentifici) setarile pentru camerele tale https://graph.api.smartthings.com/ide/devices 189
Setarile pentru vista cam sunt aceleasi ca pentru Foscam,practic e o rebranduire a camerei. Acestea sunt setarile:
/** * Foscam - FI8910W * * Ascary:
[email protected] * Ascary:
[email protected] * Author:
[email protected] * Date: 01/29/2014 * * Modified this to work with FI8910W * * Modified example Foscam device type to support dynamic input of credentials * and enable / disable motion alarm to easily integrate into homemade * security systems (when away, mark "alarmStatus" as "on", when present, mark * "alarmStatus" as "off". For use with email or FTP image uploading built * into Foscam cameras. * * Capability: Image Capture, Polling * Custom Attributes: setStatus, alarmStatus * Custom Commands: alarmOn, alarmOff, toggleAlarm, left, right, up, down, * pause, set, preset, preset1, preset2, preset3 */ preferences { input("username", "text", title: "Username", description: "Your Foscam username") input("password", "password", title: "Password", description: "Your Foscam password") input("ip", "text", title: "IP address", description: "The IP address of your Foscam") input("port", "text", title: "Port", description: "The port of your Foscam") } // for the UI metadata { tiles { carouselTile("cameraDetails", "device.image", width: 3, height: 2) { } standardTile("camera", "device.image", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false) { state "default", label: "", action: "Image Capture.take", icon: "st.camera.dropcam-centered", backgroundColor: "#FFFFFF" } standardTile("take", "device.image", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false, decoration: "flat") { state "take", label: "", action: "Image Capture.take", icon: "st.secondary.take", nextState:"taking" } standardTile("up", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") { state "take", label: "up", action: "up", icon: "" } standardTile("alarmStatus", "device.alarmStatus", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false) { state "off", label: "off", action: "toggleAlarm", icon: "st.camera.dropcam-centered", backgroundColor: "#FFFFFF" state "on", label: "on", action: "toggleAlarm", icon: "st.camera.dropcam-centered", backgroundColor: "#53A7C0" } standardTile("left", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") { state "take", label: "left", action: "left", icon: "" } standardTile("pause", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") { state "pause", label: "pause", action: "pause", icon: "" } standardTile("right", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") { state "take", label: "right", action: "right", icon: "" } standardTile("blank", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") { state "pause", label: "", action: "pause", icon: "" } standardTile("down", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") { state "down", label: "down", action: "down", icon: "" } standardTile("set", "device.setStatus", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false) { state "set", label: "set", action: "set", icon: "", backgroundColor: "#FFFFFF" state "setting", label: "set mode", action: "set", icon: "", backgroundColor: "#53A7C0" } standardTile("preset1", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") { state "preset1", label: "preset 1", action: "preset1", icon: "" } standardTile("preset2", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") { state "preset2", label: "preset 2", action: "preset2", icon: "" } standardTile("preset3", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") { state "preset3", label: "preset 3", action: "preset3", icon: "" } standardTile("refresh", "device.alarmStatus", inactiveLabel: false, decoration: "flat") { state "default", action:"polling.poll", icon:"st.secondary.refresh" } main "alarmStatus" details(["cameraDetails", "take", "up", "alarmStatus", "left", "pause", "right", "blank", "down", "set", "preset1", "preset2", "preset3", "refresh"]) } } def parseCameraResponse(def response) { if(response.headers.'Content-Type'.contains("image/jpeg")) { def imageBytes = response.data if(imageBytes) { storeImage(getPictureName(), imageBytes) } } } private getPictureName() { def pictureUuid = java.util.UUID.randomUUID().toString().replaceAll('-', '') "image" + "_$pictureUuid" + ".jpg" } private take() { log.debug("Take a photo") httpGet("http://${settings.ip}:${settings.port}/snapshot.cgi?user=${settings.username}&pwd=${settings.password}&resolution=32&rate=0") {response -> log.debug("Image captured") parseCameraResponse(response) } } def toggleAlarm() { if(device.currentValue("alarmStatus") == "on") { alarmOff() } else { alarmOn() } } private alarmOn() { api("set_alarm", "motion_armed=1") { log.debug("Alarm changed to: on") sendEvent(name: "alarmStatus", value: "on"); } } private alarmOff() { api("set_alarm", "motion_armed=0") { log.debug("Alarm changed to: off") sendEvent(name: "alarmStatus", value: "off"); } } def left() { api("decoder_control", "command=6") { log.debug("Executing 'left'") } } def right() { api("decoder_control", "command=4") { log.debug("Executing 'right'") } } def up() { api("decoder_control", "command=0") { log.debug("Executing 'up'") } } def down() { api("decoder_control", "command=2") { log.debug("Executing 'down'") } } def pause() { api("decoder_control", "command=1") {} } def preset1() { preset(1) } def preset2() { preset(2) } def preset3() { preset(3) } //go to a preset location def preset(def num) { if(num == null) return if(device.currentValue("setStatus") == "setting") { setPreset(num) } else { log.debug("Go To Preset Location") //1 is 31, 2 is 33, 3 is 35 def cmd = 30 + (num * 2) - 1 api("decoder_control", "command=${cmd}") {} } } //set the preset number to the current location def setPreset(def num) { log.debug("Set Preset") //1 is 30, 2 is 32, 3 is 34... 8 is 44 int cmd = 28 + (num * 2) sendCmd(cmd) log.debug("Exit Set Mode") sendEvent(name: "setStatus", value: "set"); } //toggle the the mode to set the preset def set() { if(device.currentValue("setStatus") == "set") { log.debug("Entering Set Mode") sendEvent(name: "setStatus", value: "setting"); } else { log.debug("Exit Set Mode") sendEvent(name: "setStatus", value: "set"); } } def api(method, args = [], success = {}) { def methods = [ "decoder_control": [uri: "http://${ip}:${port}/decoder_control.cgi${login()}&${args}", type: "post"], "snapshot": [uri: "http://${ip}:${port}/snapshot.cgi${login()}&${args}", type: "post"], "set_alarm": [uri: "http://${ip}:${port}/set_alarm.cgi${login()}&${args}", type: "post"], "reboot": [uri: "http://${ip}:${port}/reboot.cgi${login()}&${args}", type: "post"], "camera_control": [uri: "http://${ip}:${port}/camera_control.cgi${login()}&${args}", type: "post"], "get_params": [uri: "http://${ip}:${port}/get_params.cgi${login()}", type: "get"], "videostream": [uri: "http://${ip}:${port}/videostream.cgi${login()}", type: "get"] ] def request = methods.getAt(method) doRequest(request.uri, request.type, success) } private doRequest(uri, type, success) { log.debug(uri) if(type == "post") { httpPost(uri , "", success) } else if(type == "get") { httpGet(uri, success) } } private login() { return "?user=${username}&pwd=${password}" } def poll() { api("get_params", []) { def params = "" it.data.eachLine { if(it.startsWith("var alarm_motion_armed=0")) { log.info("Polled: Alarm off") sendEvent(name: "alarmStatus", value: "off"); } if(it.startsWith("var alarm_motion_armed=1")) { log.info("Polled: Alarm on") sendEvent(name: "alarmStatus", value: "on"); } } } }
