Xiaomi Mi 11 Ultra alternativa Galaxy S21 Ultra
Xiaomi Mi 11 Ultra este cel mai puternic și bine dotat smartphone lansat până acum de producătorul chinez, cu tinta clara Samsung Galaxy S21 Ultra. Un flagship cu dotari si aspect premium avand sasiul din aluminiu, spatele ceramic si certificat IP68 (rezistent la praf si apa la o adancime de 1,5 m timp de 30 minute) ce se vrea a fi o alternativa ceva mai accesibila la S21 Ultra.
Ca si harware oferit Mi 11 Ultra nu este foarte diferit de versiunile deja lansate:
1. DISPLAY
  • display AMOLED, 1B culori, 120Hz, HDR10+, 900 nits, 1700 nits (peak)
  • diagonala display 6.81 inches, 112.0 cm2 (~91.4% screen-to-body ratio)
  • rezolutie display 1440 x 3200 pixels, 20:9 ratio (~515 ppi densitate)
  • protectie Corning Gorilla Glass Victus
  • Dolby Vision
2. VERSIUNI MEMORIE INTERNA UFS 3.1
  • 256 GB cu 8 GB RAM
  • 25GB cu 12 GB RAM
  • 512 GB cu 12GB RAM
  • fara slot card memorie
3. MODUL CAMERE
  • principala 50 MP, f/2.0, 24mm (wide), 1/1.12", 1.4µm, Dual Pixel PDAF, Laser AF, OIS
  • 48 MP, f/4.1, 120mm (periscope telephoto), 1/2.0", 0.8µm, PDAF, OIS, 5x optical zoom
  • 48 MP, f/2.2, 12mm, 128˚ (ultrawide), 1/2.0", 0.8µm, PDAF
  • Dual-LED dual-tone flash, HDR, panorama, 1.1” AMOLED selfie display
  • Rezolutii video 8K@24fps, 4K@30/60fps, 1080p@30/60fps, gyro-EIS, HDR10+ rec
4. CAMERA SECUNDARA
  • 20 MP, f/2.2, 27mm (wide), 1/3.4", 0.8µm
  • HDR, panorama
  • Rezolutii video 1080p@30/60fps, 720p@120fps, gyro-EIS
5. PLATFORMA
  • OS Android 11 cu MIUI 12.5
  • Chipset Qualcomm SM8350 Snapdragon 888 (5 nm)
  • CPU Octa-core (1 x 2.84 GHz Kryo 680 + 3 x 2.42 GHz Kryo 680 + 4 x 1.80 GHz Kryo 680)
  • GPU Adreno 660
6. CONECTIVITATE
  • Wi-Fi 802.11 a/b/g/n/ac/6e, dual-band, Wi-Fi Direct, DLNA, hotspot
  • Bluetooth 5.2, A2DP, LE, aptX HD
  • GPS tri-band A-GPS, GLONASS, BDS, GALILEO, QZSS, NavIC
  • NFC
  • Port Infrarosu
  • FARA Radio FM
  • USB Type-C 2.0, USB On-The-Go
6. SUNET
  • difuzoare stereo in colaborare cu Harman Kardon
  • FARA jack de 3.5mm
  • 24-bit/192kHz audio
7. ACUMULATOR
  • Li-Po 5000 mAh, non-removable
  • Fast charging 67W, 100% in 36 min
  • Fast wireless charging 67W, 100% in 39 min
  • Reverse wireless charging 10W
  • Quick Charge 4+
  • Power Delivery 3.0
8. SENZORI
  • amprenta (sub display), accelerometru, gyro, proximitate, busola
Lista dotărilor este completată cu certificare IP68 împotriva pătrunderii de apă și praf, difuzoare stereo optimizate de specialiștii Harman Kardon și un motor de vibrații ultra-performant.
Pornind de la versiunea cu dotări de bază, având 8GB memorie RAM și 256GB stocare internă, prețul lui Xiaomi Mi 11 Ultra poate ajunge la 1065dolari, pentru versiunea cu 12GB memorie RAM și 512GB stocare internă.
In testele sintetice DxOmark https://www.dxomark.com/xiaomi-mi-11-ultra-camera-score-a... Xiaomi MI 11 Ultra a depasit liderul de la acel moment Huawei Mate 40 Pro+, obtinand un scor de general de 143 puncte (148 puncte camera foto, 117 puncte camera video si 100 puncte zoom). Prin comparatie Huawei Mate 40 Pro+ a obtinut un scor general de 139 puncte.
Nu exista preturi oficiale pentru acest produs, dar zvonurile si analistii din piata preconizeaza un pret ceva mai mic in comparatie cu Galaxy S21 Ultra.
  • 814 dolari pentru varianta 8GB/256GB
  • 1065 dolari pentru varianta 12GB/512GB version
Sursa - https://www.gsmarena.com/xiaomi_mi_11_ultra-10737.php
FaraUnID
FaraUnID
FaraUnID
FaraUnID
am cautat "cateva" diferente "esentiale" dar deocamdata "netu-l" gsmarena sau kimovil inca testeaza .. ce este evident deocamdata este faptul ca xiaomi este mai scump decat samsung ! (la o paralela) .. am sa revin cu date noi in timp ...
mihai_13
mihai_13
mihai_13
mihai_13
Problema la Xiaomi rămâne în continuare softul, care este instabil la fiecare update major. Ușor, ușor și chinezu ridică bine prețul, se apropie deja de preturi premium.
Xiaomi Mi 11 Ultra apare in testele Geekbench ca ruland Android 12.
Rezultate obtinute:
  • 1116 puncte in Single-Core
  • 2845 puncte Multi-Core
Posibil ca versiunea de Android 12 care motorizeaza modelul de test sa nu fie una finala, prin urmare nu foarte optimizata, iar rezultatete sa nu fie cele mai concludente.
Sursa - https://browser.geekbench.com/v5/cpu/8488826
FaraUnID
FaraUnID
FaraUnID
FaraUnID
Salut, Rudy! Am luat legatura cu colegii nostri pentru mai multe informatii in acest sens. Din pacate, nu exista planuri legate de introducerea telefonului Xiaomi Mi11 Ultra in oferta Orange . :-(
Orange Assistant
Orange Assistant
Orange Assistant
Echipă
Orange Assistant
